Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
Did you fit these yourself?
Can you see the rubber mounting piece between the spring top and the chassis nipple?
I'd say there on the right way but perhaps too soft a spring rate as there doesn't seem like much room for movement there
Not done the suspension on my LC, but all other cars i've done, clio, fiesta etc.. the spring is progressively wound to be closer coiled at the bottom.
Ive just fitted some on my lcr this is the correct way round , the spring will not sit the other way round because the top coil is to small to pass over the hight adjuster it does seem odd but when i looked in the instructions it was correct
