Leon Door Lock Problem
TINCAN
246
MK
I have a problem with door locks on a Y plate Leon Cupra. Basically the key fob has stopped working so for now i was using the key in the lock however this too is now not working. The problem is when turning the key in the lock the windows wind down or up (depending how i turn the key) but the locks do not operate. To make things worse the windows also continue to go down/up even when i remove the key.
For now we are locking the drivers door from inside and climbing out of the passenger door.
Is this just a case of sticking lock or ??? electrical problem?
bentaw
Revo'd LCR
Oct 1, 2004
1,067
Hampshire
i have a similar problem by rear drivers side door wont open and the car wont lock unless i press the fob twice starting to do my head in now
gorillaleon
mine started playing up last night now when i lock with the key the only door to thats locks is the one the key is in where as the fob locks all. and this also happened at the same time the little lock button inside now only locks drivers side of the car :( i am blaming the wet weather has got in sumwhere but all fuses are fine. x reg 20vt
did you check ure fuses?
might be worth popping of door cards to have a check all looks well?
