Nef
Looking Rather Dappa
Mar 30, 2009
626
Cambridge
would a set of golf mk4 front and rear seats fit straight into my 2002 leon. says its from a 3 door but surley they should still fit my 5 door, right?
thanks for any help.
ken
I fitted mine last month, very easy job but the airbag multiblocks are different......if you have airbags.
Easily sorted out tho :)
Passenger seat wiring;
Loom Brown to Airbag Brown
Loom Blue to Airbag Blue
Loom White to Airbag Black
Drivers side;
Loom brown to airbag brown
Loom white to airbag blue
Loom green to airback black
I was lucky enough to sell my seats to someone who didnt need air bags so I cut the multi blocks off my old seats and joined them to the new ones.
quality, thanks for the help mate. anything else i should know. can you get the connects anywhere else apart fron the OEM seats?
Just cut both connectors off and use bullet connectors.
I was told not to solder as it could slightly change the resistance....how true this is I don't know.
Are they heated? if they are this is a bit more work as you need the carpets up to run the loom through.
If not its a very very easy swap.
Cheers pal, nah there not heated.
LOL, yeah wish i could afford a set of R32 ones. the golf recaros are still a step up from the cupra ones.
Being a bit anal about such things, it would bug me having the 3-door tilts in a 5-door car so I'd have held out for a set of 5-door Recaro's though!! I bought a complete interior with door cards etc a few years back for a Golf I had (Grey on black) for £400 from our fave auction site. Really good seats and worth the change over. Had to change the plugs too - all of 10 mins work using soldered connections and heat shrink over the joint and no issues with airbag lights.
Thats what I done...held out for a 5 door set....they come up more than you think :D
