Cutting Off!
CupraGTI16V
Ibiza Cupra
Oct 10, 2009
116
Turkey
Everyone Hi. I am new here. My English is not perfect. Sorry for that. I own 1999 Seat Ibiza Cupra (ABF).
From 2 month my car have a cutting problem. When i give full throttle it sometimes cutting off. My car is about 165hp. But now it goes like 120hp. I spend too much money to avoid this problem but i couldn't. I changed crank sensor, lambda sensor, distrubutor cover, spark cables, sparks, fuel pump, ignition coil and some others. In my country, parts of this car are very expensive. I spend more than 1000€. When i plug the car to VAG, it gives an error (the code is G145). But Seat Servicez couldn't solved it. I need your help. Thanks.
Cupra Kid
Has a TDI!!
Oct 13, 2005
3,380
Chesterfield, Derbyshire
i would have a look at the throttle body (where the pipe from the air box joins the engine) these get clogged easily and could cause this.
Other things to check for this would be the coil and the actual distributor itself
CupraGTI16V
Ibiza Cupra
Oct 10, 2009
116
Turkey
maf sensor? air filter? just give it a basic service
Air filter is new. No problem with the maf sensor.
I replaced distrubutor with a second hand. It was very expensive. But it is not the problem. It still continued. I changed that air filter pipe and also cleaned throttle body.
rubjonny
G145 is a crank sensor error, though it can be triggered if you check for faults with the engien off.
is the crank sensor a new one? also get the timing checked
