Hi James
Well yes it would definetely
help, even going to 256's would be a step in the rearward direction in terms of balance and just before I start harping on its a rearward adjustment NOT rearward Bias Im advocating just something to
help out a little.
The 284's and 300mm rears (4wd cars) have a tangible effect on how the car feels under braking, it feels more like the car is being pulled to a stop from behind rather than the fronts doing all the work it also eliminates a lot of dive that the front end gives on unmodded suspension and complements a 1/2 decent set of coilies and springs.
Just to repeat though FWD 256 rear setups WONT work, you need to change your setups to TT 256's or 4mo or R32 setups, these setups require a set of 6mm spacers to work in the past which were around the 30 quid mark, that 6mm and much more is taken up by a fairly chunky bracket that for all intents and purposes moves the mounting points for the rear calipers outwards to wards the rear of the car facilitating the bigger disc, by fiting the 6mm spacers you can remove it all and go back to a 256mm setup easily.
Theres been a lot of success over ont he other forum with people swapping their caliper carriers for those of another user. So golf owner with 232's can only find 4WD setups from breakers etc, he needs to buy the spacer kit, FWD owners such as 180BHP GTis, Anni, Cupra's, Octy VRS's want the 4WD carriers to do the conversion so they swap carriers keeping your existing calipers - normally have paint issues but thats not insurmountable.
If you have a set of TT rear calipers/carriers under your stairs and you are looking at buying OEM discs and the spacer kit then for not much more you can go staight to 284s fairly cost effectively.
If you have a FWD 256mm kit with discs/caliper/carriers and its bolt on then you have some more thinking to do.
I'll try to dig some pics out and post them up
