N75 Valve Question
Mr Roboto
Domo Arigato
Mar 14, 2005
470
Sussex
Regarding the N75 which I need to replace. Is it worth investing in the ECS race N75 valve or just stick to the standard SEAT one and save about £20?
Mr Roboto
Domo Arigato
Mar 14, 2005
470
Sussex
I take it that a faulty N75 can cause boost hesitation without causing a fault?
If I disconnect the MAF then the cars runs fine.
MAF has been replaced 3 times to rule out a duff one.
On lite throttle I get boost hesitation which makes the DV dump loads of times then a surge of boost.
Am I going in the right direction with the N75?
Witalik
ROTTERDAM FEYENOORD
Dec 28, 2008
324
Netherlands
i have got this too after my remap. when driving 100km/h en i want to accelerate with only little gas it also hesitates spool no spool kinda thing....
tomorow i get my hoses checked for leaks or anything and if that aint work i could wel be the n75 or the maf, not much else that does anything with the boost ? (wastegate)
Witalik
ROTTERDAM FEYENOORD
Dec 28, 2008
324
Netherlands
with mine got today to a garage, and both the TIP en the other hose on the turbo were lose and or faulty,
i got a little les hesitation now but it is still there...
so i dont know if the n75 is the only thing here that could cause this ????
Dani_b19
301
Its fine, you'll just get a flat spot between 2500-5000 rpm, just dont do it for too long.
wayne lcr
bored of it now
Mar 5, 2009
4,548
doncaster
good point mine got a bit of a flat spot it dint do it when i bought it just in the last few months any idea what it could be?
Pabs
5,936
Basingstoke
Is it safe to go for a quick drive with the N75 unplugged or will this cause damage?
From my understanding, the N75 routes boost pressure to keep the wastegate CLOSED. With it disconnected, it'll never open, meaning that the pressure will always be routed to keeping the wastegate closed... thus overboosting.
The N75 bleeds off boost to the TIP in order to allow the wastegate to open.
Witalik
ROTTERDAM FEYENOORD
Dec 28, 2008
324
Netherlands
what is meant by getting a flat spot ?
i thought this valve is used to open the waste gate ? if it is unplugged it wont open ? if u have a mapped car would that be to much boost ?
Rarpuc
137
west of scotland
On my previous car (octavia vrs) which had the 180bhp 1.8t after a remap i got pretty awful hesitation,initially i changed the n75 for a new standard one but the problem remained i then went for the ECS race n75 and it all but solved the hesitation. it would still crop up from time to time but it was no where near as bad as it had been.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
nope.. not quite
with N75 'electrically" disconnected all boost pressure route to actuator, which when it gets past its spring pressure of 5psi (approx) it then opens, so max boost is actuator pressure.
n75 keeps wastegate closed when its on full duty cycle maximum on, so routing most of the air to the intake pipe so the actuator does'nt see boost so does'nt open, thus being uncontrolled boost until n75 duty cycle drops down again.. (ecu controlling now for target vs actual boost request)
regards
bill
Pabs
5,936
Basingstoke
lol - i always seem to get it the wrong way around!
So what you're saying Bill, is that the normal state, n75 is always "closed" thus pressure routing to actuator, opening this earlier than it should - so you'll never see more than 5psi of boost with N75 disconnected.
Correct? (I hope so!)
So to achieve higher boost, the N75 bleeds it off to the TIP to keep the wastegate closed.
Phew - I think I'll keep this thread bookmarked for a read when I'm not so tired! :p
Mr Roboto
Domo Arigato
Mar 14, 2005
470
Sussex
Some thing is conflicting with the MAF as with it disconnected the car runs perfect.
So is it wise for me to unplug the N75 for a sort drive or not?
What else can be linked to the MAF to cause my boost problem.
Pabs
5,936
Basingstoke
Yeah mate - I think it's the way I read it confused me - the boost might build up, but the pressure through the N75->actuator DECREASES it to keep the actuator closed... (it is sent to the TIP instead).
