After returning from a spirited ride with 20c degrees ambient temp. with the mk3 1.8 20vt, I noticed the oil temp. at 110c and when parked at the end of the ride , the Water temp. rose above 90 degrees just slightly .
I should say that I'm with a brand new metal impellor water pump and LM 5W40 oil. Doesn't happen at high speeds.
The secound fan's fuse is blown . Should the secound fan come on at high speeds at all or only for AC?
So whadya think??
Thin oil?
Water/oil leak?
fan # 2 ?
Anything else?
Thanks in advance for your valued input.
So whadya think??
Thin oil?
Water/oil leak?
fan # 2 ?
Anything else?
