lever identification required .. help please
liza283
hya peeps, me again, i have a dseat ibiza 1995 diesel. at the side of the steering column is a lever. can someone tell me if this is a manual choke? i need to replace it and don't know what the name is of that part. thanks in advance, liza 283
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
cold start cable or choke as you say, just point out it's a diesel and i'm sure a decent parts guy will figure out what you need, in fact try a few of our own here if it helps ?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
Cold Starting Aid Cable and assuming it's RHD and upto '96
#1 cable - 6k2 711 501
#4 lever on end - 6k2 711 503
(if you get stuck at the dealers tell him illustration 711-65) :)
liza283
hya, the diagram shown in the reply looks like it. its numbered i noticed. the part i need is the one marked 4. it snapped off. do i have to buy the whole assembly? it was also mentioned that you can obtain parts from here?? or am i mistaken? when i search for the part, what is that number 4 part called? does it have a technical name? many thanks guys, you're all very helpful, whether its because im female that i cant seem to make myself understood when i try and explain to peeps. thanks again guys. liza283 :happy:
