exhaust mounts numbers please
RichN
Collecting Rings
Jan 29, 2005
533
Oxford
www.Oxford7s.net
Hmmmm.... The very final mount is called a SHACKLE in Etka.. Although it's listed as compatible with the Cupra 'Bosal' exhaust, I'm not sure it looks the same as the one on my Cupra so check very carefully before you buy!
It lists part no: 6K0 253 674
chrisbond69
chris bond
Jun 11, 2005
1,297
Cirencester, Glos
been under removed both items the number on the rubber part of the bush reads 6k0 253 147 but dont let this fool you like it did me the rear items are item 6K0 253 674 They retail 13.50 plus vat each and for the third bush in from the back then you can use the normal bush mentioned at the start, hope this helps anyone
RichN
Collecting Rings
Jan 29, 2005
533
Oxford
www.Oxford7s.net
And rich you were right well done
Ah cool. Sorry for being a bit under-confident.. ETKA diagram looks nowt like mine - must be because mine was replaced when the blueflame was changed.. and then changed again to Milltek. Mine's a sticky-out-spike thing.. the Seat one looks like a holdy-hanger sort of thing.
chrisbond69
chris bond
Jun 11, 2005
1,297
Cirencester, Glos
its a two bolt bracket with item 6k0 253 147 mounted on it so no way the rubber can be removed without cutting it off i have a pic buy internet is to slow to post on photobucket then on here
