Welded catalyst or flanges?
Faisal
UK's 1st Liquid Yello LCR
May 27, 2008
1,445
Most likely at work
Hello,
i have had a sports cat installed a long way back by RMS in prestwick (i have heard mixed reviews from them ever since).
i do have one issue, they used a flange for the sports cat, and recently my exhaust sounded burst, it turned out that it needed repasted. had to travel all the way down to get that done. it worked, car was fine for a good while, but now im getting the same sound as i had before, and puffs of blue smoke on start up.
basically i need to go again (this is very impractical for me).
i asked them why they don't just weld it on and they said that it means the whole exhaust has to come off if there are any issues with the cat, which is why they use flanges.
the question is, should i go back and just get it repaste again?or should i pester them into welding it so it doesnt arise a 3rd time? is there any major drawbacks from having it welded?
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Its up to you what is best, its your car not theres.
I'd get it welded and forget about it.
They don't seem to have much hope of there CAT lasting long
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
they are putting paste on a flange in front of a cat ? hope not
personally i would ask them for one with a flat flange so you can bolt it up properly
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
well exhaust paste is designed to harden like concrete once it gets to a temperature and if it's spread too thick when put together it will just sit in the front of the cell of the cat and block it up (well part of it)
never use paste in front of a cat and i prefer using rtv silicone anyway, paste is jank if you have to re-assemble anything later
have a look under it yourself when you go back to decide on welding as that would be the best seal/solution but you need to consider removal access (to cut it off) should you need to and also why it keeps blowing anyway ?
either the surfaces are not flat and sealing properly or vibration is causing them to open up
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
for example just think how free-flowing this would be if it had gobs of concrete play-do spread all over the front of it ?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
metal gasket sometimes a metal cone ring type design, all depends on who/how it's designed to be honest
