16v Headlights Dipped/Mainbeam
critch4
Ibiza GTi 16v Cupra Sport
Aug 20, 2009
119
Newcastle
Hi all,
I have a question about the headlights on my GTi 16v, are the dipped beams meant to go out when you put the full beams on? Because mine do and the full beams are pretty much useless! I've tried adjusting the horizontal/vertical spread of the full beams but it hasn't made much difference. I've checked the bulbs and i've checked the wiring and they're all fine. If I hold the dipped beam/full beam stick towards me both bulbs stay on and it seems like this is how it should be (but i cant go driving around holding the indicator stick towards me constantly when on full beams :help:)
Thanks,
Andy
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
Yep they the dipped beams go off when you put your full beam on.... unless u hold it like you said. They use the same bulbs but the full beam is adjusted so goes futher I guess but it's not the best.
I've got some Osram Nightbreaker bulbs and found they have improved the lighting loads as it says on the box "10% whiter and 90% brighter" gives a nice white look to the lights to.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
mine stay on when flashing and placed on high beam from memory
only thing i have done is unplug the lamp resistor because of the hid's and wired the the front fogs with a diode to the high beam so i get all 6 lit up
Cupra Kid
Has a TDI!!
Oct 13, 2005
3,380
Chesterfield, Derbyshire
Well you got a magic one, the two chambers just make it look pretty compared to the 1.4's etc... ;)
Been out to check the GTi - high beam inner chamber dipped beam outer chamber. Both stay on :D
On our 1.4 the single chamber lights switch off dipped beam when high beams turned on.
Dedication and sadness all in one!
Jun 14, 2005
920
Northants.
Lamp resistor?
Will unplugging this mean that I can have HID main and high beam on together?
Cheers!
DC
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
Lamp resistor?
not sure but that is the only thing from standard i have done to mine
mind you thinking about it there is a relay rigged up to the twin lamp conversion (pluggs into standard loom)
might be that doing it instead
andyj
There's no F in Quality..
I fitted Gti headlamps to my old 1.4 Mk2, and they were the same, dipped went out when you put full beam on.....
First time I had it MOT'd with them fitted, they tried failing it..... until I got in touch with the local VoSA office, who rang the garage and reminded them of the MOT requirements ;)
T108
312
yep all gti's cupras have twin bulbs and the dip beam stays on with the main
T108
312
that is wierd, so some of us have twin bulbs and both stay on, so we have better headlights!! :D
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
they go off on main but are on when you flash. the side lamp bulbs stay on though, maybe this is what confusses people though.
