The actual screen unit looks pretty small, I can't see why you wouldn't be able to make something like a pillar pod to hold it........now theres an idea
The actual screen unit looks pretty small, I can't see why you wouldn't be able to make something like a pillar pod to hold it........now theres an idea![]()
The screen itself looks tiny. I wonder if it can fit in the cup holder area?
...I wonder if it can fit in the cup holder area?
Probably, if you remove the cup holder itself. Now if you can make it hinged around the cup holder so I can pop it in and out as necessary and it'll lay flat/spring up as necessary, that would be great![]()
Fill the heater trunking with the bubble wrap, will protect the Gauge from any heat![]()
I'd like to know this too...I would prefer one in the centre vents (left or right not bothered) rather than the side vent as it is useful for demisting the drivers window and I never really use the centre vents!![]()
First time this morning i had to demist my windscreen/side windows and my drivers window demisted fine just by the vent on top of the dash.
