My first vag com logs,whats the verdict please?
Jul 29, 2006
723
cumbria
www.facebook.com
here is my first logging,could any of you guys comment on how the figures look and is there other blocks i should be logging,this was my 2nd run,4th gear 40mph through to red line.
Code:
	Group A:	'002
		Idle speed	Engine load	Inj. period	Air mass in
	TIME	700-820 rpm	15-25%	2.0 - 4.0 ms	2.0-4.5 g/s
Marker	STAMP	 /min	%	 ms	 g/s
	0	2520	120.3	13.94	65.78
	1.3	3000	149.6	17	82.11
	2.51	3400	158.6	19.04	105.42
	3.71	3800	148.9	19.38	107.22
	4.93	4240	151.9	19.38	122.92
	6.24	4640	148.1	19.04	130.58
	7.55	5040	145.9	20.06	140.53
	8.96	5400	139.8	19.38	143.67
	10.37	5680	136.8	19.38	149.67
	11.57	5920	133.8	19.38	151.94
	12.88	6080	132.3	19.38	154.89
	14.08	6280	130.8	19.04	155.89
	15.39	6440	128.6	18.7	155.89
	16.7	6600	124.1	18.02	157.78
	18.01	6720	123.3	18.02	156.53
	19.21	6840	120.3	17.68	156.83
	20.43	6960	121.8	18.02	158.72
Monday	14	September	2009	19:39:31
06A 906 032 MJ		1.8L R4/5VT         0003
Code:
Group C:	'020
	Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
TIME
STAMP	 CF	 CF	 CF	 CF
0.9	6	3	6	6
2.11	6	3	6	6
3.31	6	3	6	6
4.53	6	3	6	5.3
5.73	6	2.3	5.3	5.3
7.15	5.3	5.3	5.3	5.3
8.54	4.5	5.3	4.5	4.5
9.95	4.5	4.5	7.5	3.8
11.17	3.8	7.5	6.8	3.8
12.38	3.8	6.8	6.8	3
13.68	3	6.8	6	3
14.99	3	6	6	2.3
16.3	2.3	6	5.3	5.3
17.6	2.3	5.3	4.5	8.3
18.81	1.5	4.5	7.5	7.5
20.01	0.8	4.5	6.8	7.5
21.23	0	0	3.8	3
Cheers.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
003, 118, 115,020, 031, and 032 are a good starting point.
Do no more than 2 at a time to get any reasonable samples.
003 and 020, then 115 and 031, then 118 and 032.
This gives you, airflow, actual timing, timing pull, requested boost, actual boost, target air fuel, actual airfuel, n75 duty, inlet temp, actual boost, and then finally fuel trims.
MAF readings looking a bit low , with CFs a bit high.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
cheers Dave,but for a car thickie,what does that mean mate:confused:
is the maf on its way out? and what are CF's and what controls them,sorry for my ignorance:redface:
I'd like to see more logs (as quoted) before passing judgement. CFs (correction factors) mean the ecu is pulling back timing because things are getting a little hot in the combustion chambers - poss running lean because the maf is on its way out and is reading less air than is actually flowing.
KNPhoto
where in cumbria did you get this done mate?
I will be looking for somewhere in due course I would say.
K
KNPhoto
Hi mate,get what done?
If you mean vag-com i have it,you in cumbria? where abouts?
Hey. I am talking about Vag-Com yeah.
I am in Carlisle, but often work all over the county.
Whereabouts are you?
I am picking my LC up today, all going well. So just scouring the net looking for decent garages/workshops for servicing, etc.
Help appreciated on that front! :D
Jul 29, 2006
723
cumbria
www.facebook.com
Hi mate,am in whitehaven,so can't really help you with carlisle area,there was a guy on here cupramatt,from carlisle,if he's still around he'll be able to put you onto the right ppl in your area mate.Hope you get the car picked up and enjoy it mate,I love my LC.
