As the heading says really, have you bothered to fit a colder plug post modifications.
It's a bit of a dark art, and there isn't much conclusive information on the interweb.
I've called JKM this morning to enquire about some NGK Iridium BKR7EIX's
http://www.jkm.org.uk/performance/tfsimisc.htm
to replace the standard recommended plug BKR6EIX. I found these run far better than the Bosch ones used as OEM (see pic below, Bosch Platinum on right , NGK Iridium on left - please note the NGK has covered far more miles and under more modified settings).
The plugs are supposed to last according to manufacturers guidance up to 60k in your average car. However in some cases (particularly HPFP etc...) you are pushing so much more fuel in that the air/fuel mix will be wearing your plugs down quite a bit faster. A chap who visits a garage I use had a tip come off a plug recently and it caused massive damage.
So just looking for any thoughts, experience, or whether anyone has any 'hard facts' as to what this may do for general use on our cars.
For more info on NGK Iridium IX plugs look here: Link
