Trouble indentifying parts
jammycupra
Hi all,
Have found the pipes I need to replace under the inlet manifold (I think they are breathers). Have found them on VAGCAT but they are not listed as anything.. hmmm
They are numbers 26, 27 and the line inbetween 28/29.
Anyone know the numbers for these and are these the ones prone to failing? Can't see any splits in them without taking them off but they are coated in oil, I reckon its leaking around the nipples. Would this make any impact on performance?
Nev_LCR
Gone... but not forgoten
May 16, 2007
1,271
Ipswich, Suffolk
hi, cant see the link but yes oil breather, they do split and cost about £16, pain to get to as the clips are an arse to get off,
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
line between 28/29 means you need #25 complete
25 06A133751K suction jet pump
that will come as listed with 26+27 anyway as it shows but
26 see illustration: 103-85 (etka page reference)
27 06A133783G angled hose
jammycupra
Ah got it, so if I get the lot it will include all the bits I need? Does that include clips? Not looking forward to making the call it sounds expensive !
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
#25 would be the main part and the umbrella means it will come with all parts directly lined under it plus *26 *27 *28 *29 *31 *32 *33 *30
most clips are listed as included but fitting wise it appears there are a few additional clips you will likely need but they are cheap enough
*18 x3 (poss just 2)
*34 x2
*35 x1
*37 x1
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
no worries
part numbers wise get the dealer to check on chassis etc prior to order as VAGCAT is useful to look at but info wise is a bit out of date sadly
if you wanna save some dosh try some of the dealers on here, SEREmotors etc will probably get you some SCN discount, support those that support us:):)
jammycupra
no worries
Had a word with the dealer, couldn't find 06A133751K - apparently its superseeded by the same number but with AE on the end.. he said it was the same bits though. All the clips were spot on, it all came to 58 quid including the VAT. Better than I thought !
