Service my own car?
ando
246
homepage.eircom.net
Hi Guys,
I have a Cupra R that needs a service but money is extremely short this month, has anyone serviced their own car here, whats involved? Is it worth trying to do myself? I top up on engine oil a good bit but thats as advanced as I get :shrug: :confused: Would it be worth the hassle or wait another month to get it properly serviced?
Mar 29, 2007
1,207
Berkshire
Depends on the service. If it's just oil and filters then it's do-able if you can get under the car. If it's brake fluid and sparks etc. you might prefer a garage to do it.
Jimski
Back to the fold!
Nov 3, 2007
1,350
Staffs
Oil filter, oil and sump plug is a 30 - 35 quid job using SEAT parts and Mobil 1 Super S oil.
Jimski
Jimski
Back to the fold!
Nov 3, 2007
1,350
Staffs
I always attack it from underneath with a big set of grips and then do the rest from above, not too hard really,
Jimski
JimCupra
89
Bucks
Going to do the oil and filter on my Cupra on Friday, is a new sump plug required?
On previous cars Ive just put it back in after....??
Jimski
Back to the fold!
Nov 3, 2007
1,350
Staffs
I change the sump plug on every other service, however this is just personal preference, they are "stretch" bolts though.
Jimski
JimCupra
89
Bucks
Cheers Jimski, but what do you mean by Stretch bolts? Is this something to do with the expansion etc with heat?
Jimski
Back to the fold!
Nov 3, 2007
1,350
Staffs
Basically, these bolts like others, are supposed to be "torqued" up, under this tension, they flex/stretch if you follow, to remain tight.
All in tiny amounts and its all SEAT recommendation stuff, but for the sake of £1.50 you dont want half a sump bolt left in there, so every other service has always done me fine. I know some that dont even bother!
The dog bone mount bolts are stretch bolts, but iv never changed mine.
Jimski
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
stretch are 1 time use only bolts
dont think the sump plug is actually a stretch bolt though. recommended to change, due to heat of oil on the threads.
can be used again if its it good nick.
but as said for 1.50 just change it.
JimCupra
89
Bucks
Right, with you....cheers. If I get the chance I shall take a trip to the stealer then.
Just gotta get my oil filter now...Halfrauds didnt have any, but did get 6l of Mobil 1 for £38...result.
Jimski
Back to the fold!
Nov 3, 2007
1,350
Staffs
Stealers will have stock of filters, think its like 9 quid for a filter and plug mate.
Jimski
nutter_engineer
175
Haha but do you just pull on the coil packs to lift them up and out or is a special tool needed?
just pull them out, no special tool is needed. I just did this the other day, it takes a bit of time as there a few bits in the way that you'll need to undo to get access to two of them.
