i would not skinp on this part of the car, save up untill you can afford a proper solution and do it then, then it's done.
if you try and skimp then it will come back to bite you in the ass. buy cheap buy twice! i'm speaking from experiance here, when my clutch statred slipping last year i went for the cheapest option and got the CG paddle clutch for £
280 delivered. it was designed to fit on my DMF. cam to fit it and the DMF was shot and had loads of play, so had to get that replaced at the same time!
then about 15,000 miles down the road (6-8 months not sure now) started getting a rattle at idle, and alot of flywheel judder on accelleration and around 2,000 rpm, flywheel was worn out already. this was due to the harsh nature of the paddle clutch i was told, funny how i was not told that when i bought it!
so i now had to fork out for another clutch and another flywheel.
ended up getting the sachs race engineering one for £550, and also at the same time i was putting in a new engine which came with a good condition DMF so luckily i dodged another expense...
i've had about 12,000 out of that setup now and it hasn't slipped yet but the DMF judders a bit on acceleration so i have to drive around that which is kindof a pain. if i could turn back time i'd go for a Helix SMF clutch kit which retails at about £850 for the kit.
i can't post links yet as i'm new here but go to performanceclutch dot co dot uk , then goto fast road and enter your car info
