Random 'clunk' FR TDi
teepee4bh
Returning old timer
Apr 19, 2009
203
Durham
GF's FR has a random clunk from front when doing slow speed manoeuvres.
Seems to be front passenger side. Usually when turning into a road or onto drive.
I've just replaced the drop link but still doing it.
Any ideas folks?
teepee4bh
Returning old timer
Apr 19, 2009
203
Durham
I checked the usual.
Anti-roll bar bushes
Top mounts seem to be smooth running - left to right turning
Drop links are ok.
Thought it was the power steering pipes knocking on sub frame - still doing it after i moved them.
Did it again reversing off drive this morning. :confused:
Car needs to go to stealer for wheel bearing.
The only thing i noticed was a mark on roll bar and one on the steering arm. Find it hard to believe they can touch each other but who knows.
Keef83
76
Maidstone
This is one that has been discussed many times if you have a search through many people have tried lots of things but never got the clunk to go.
teepee4bh
Returning old timer
Apr 19, 2009
203
Durham
i have mate - looked at all possibilies
Only the top mounts and steering rack (god forbid) not looked at
Going to delaer monday for wheel bearing check so they can have a look too.
Keef83
76
Maidstone
post on here the results will be interested like many others as I think they tried to put it down to the Bushes once but I still get it now....
Lippo
YNWA
May 8, 2006
395
Formby
Could be wrong, but doesn't the wheel bearing check include jacking the wheel up and placing your hands at 12 o'clock and 6 o'clock and see if you can get any movement when pushing at top/pulling at bottom (and vice versa)?
You could have a quick go yourself (if you haven't already)
teepee4bh
Returning old timer
Apr 19, 2009
203
Durham
the wheel bearing is rear and really humms at approx 30mph.
The knock, clunk, bang comes from front somewhere.
keefy
344
Sure it's not the lower arm rear bushes....? Just had mine replaced at 98k miles & before I had them changed, it clunked over small bumps, particularly when manoeuvring & with some lock applied to the wheels.
Since having them replaced it's not happened once.
teepee4bh
Returning old timer
Apr 19, 2009
203
Durham
keefy, after reading your thought i had a look. you might be right like. it's becoming more frequent now but if you compare the pictures the passenger side doesn't look the same and has a rolled edge around the peg it as if it's been moving about a bit. Only a tiny movement would make a nasty sound.
Does anyone know how the bushes are gitted over this peg?
http://www.picturebay.net/img/guests/902407533/passenger_bush.jpg
http://www.picturebay.net/img/guests/902407533/drivers_bush.jpg
drivers bush looks a far tighter fit around the peg thing on back of control arm.
teepee4bh
Returning old timer
Apr 19, 2009
203
Durham
well.....
due to get car back today.
Wheel bearing acknowleged and in progress.
Knock is a mystery but technician heard it on test drive. They need to ask SEAT for advice
Must have checked all the usual failures and ran out of ideas.
While car is in they're cheking all recalls have been applied. I really hope that doesn't include plugging car into there diagnostic and changing the ECU software just because they felt like it ! I will not be very chuffed. Car runs very well so i've asked them nicely in an email to only consider any safety mechanical items and leave the rest of it alone.
Should have it back at 2pm ish.
:think:
teepee4bh
Returning old timer
Apr 19, 2009
203
Durham
the latest......it seems that the brake carrier has been hitting off the disc causing the noise.
Why this is happening is still a mystery !
back to garage again......3rd time lucky ?
teepee4bh
Returning old timer
Apr 19, 2009
203
Durham
brake carrier holds brake calliper to hub.
i'm begining to think ours is related to the drive shaft. I'm wondering if there's a bit of float on the inner joint
am i right in thinking the shaft length needs to change during turning?
