Have you ordered yours damo? If so I'll wait for yours to arrive and if it fits I'll purchase the same one.
Ordered one Damo, I'll let you know
Im debating on one of the Jetex open cones, or just a Green panel filter... Hmmm!
The OE airbox has a good airfeed, really makes you wonder that, apart from a bit louder, if the open cone is any better than a Green panel filter.
In theory anyway, as long as you have a decent intercooler then a cold air feed is worth very little. IIRC a high flow air filter taking in hot air from the engine bay was a bit up on hp compared to an enclosed cold air intake filter. As the IC was keeping the charge temp under control this extra power was gained due to the higher kg/min the turbo could suck in via the less restrictive intake setup. Obviously this only applies to forced induction engines, N/As without any cooling to the intake air will be much more sensitive to intake air temps.
hi, i am looking to buy a jetex cone filter but i don't know what size neck i need. Ive got the standard MAF, do you know what size i need please? I have a mk 3 ibiza cupraI would personally buy a jetex thats me tho
