Car just failed its MOT got a bit of a list going on. The only point I'm not so sure about is the excessive free play at the steering wheel, it seems to be from the clamp that connects the steering wheel rack to the steering, it seems to be lose. I need to check with seat they gave me the right part.
Failed on:
Failed on:
- Steering system has excessive free play detected at the steering wheel
- Nearside Headlamp too low
- Offside headlamp too low
- Off side front brake hose excessively chafed
- Brake performance not tested(because it wouldn't go on the tester and because he didn't think it was safe to drive with point 4)
- nearside front front position lamp(s) slightly discoloured
- offside front front position lamps(s) slightly discoloured
- nearside front machpherson strut has slight movement at the upper attachment
- offside front macpherson strut has slight movement at the upper attachment
- nearside rear wheel bearing has slight play
- offside rear wheel bearing has slight play
- nearside rear brake pad(s) wearing thin
- offside rear brake pad(s) wearing thin
- nearside rear seat has been removed
- a smaller steering wheel has been fitted to the vehicle
- steering wheel top mount has slight play
- reg plate slights slight dull and discoloured
- nearside front ABS wire is coming into contact with CV joint
- offside and nearside rear brake host ferrules slightly corroded
- oil leak
- vehicle has been fitted with modified suspension all round
