Just had my windscreen replaced as the old one's crack had almost reached the opposite side of the windscreen lol! The repairman had a NIGHTMARE getting the old one off, as it was apparently in too tight on one side such that he couldn't get a blade in there to cut away at the glue. In the end he ended up having to hammer around the sides and kick my windcreen out from the inside quote "the hardest windcreen i've ever removed in my career" lol!
So anyway he's put the new one in, and there's a gap at the top where the old one used to go really close to the surface, and the VIN number is only partly visible now due to the windscreen sitting a bit lower; with enough space around the sides of the screen to get it out should it need to be replaced.
My question is... is this normal? and will it be ok with a gap at the top, there is not seal there but he says it will be fine. Any pics of your windcreen from the top and near the vin? I'll upload mine in a bit
