Bleeding a Clutch
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
pressure bleeder is the easy way! if you do not have one the you can bleed it the same as how you do brakes. the bleed nipple in on the slave cylinda is on the gearbox! it uses the same fluid as your brake fluid.
