carputer
sunilbass
278
lesta
hi guys
i was thinking of putting a carputer in the car... does anyone know of any programs which i could use to moniter the car?? maybe it does a display like scanguage, race diagnostics etc
cheers
sunilbass
278
lesta
ah, nice... i can i ask what you used to connect the car to your pc?? was it just a normal vag com lead?? usb or serial?? plusr any pics!!
cheers once more for the help!!
Nabraxas
111
I'd really like to have a in-car PC as it'd be really easy for me to get a build for the boot, never really worked out in the Leon though where the screen can go - how you putting the touchscreen in the dash, guessing you'd have to try and make something or use a pop-out screen?
Not quite worked out how you get the audio to go to all the speakers either? Output on the PC will be 3.5mm jack?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
if you run a soundcard or surround sound motherboard just use the jack plugs in the back soldered to leads up front
maplins do em in bare basic form so nothing some solder and heat wouldnt cure
If you have no sunroof?? you could use a fold down roof mounted monitor as alternative, can get em bigger dimensions then of course ;)
sunilbass
278
lesta
im more than likey going to use a tracker ball mouse instead of a touchscreen moniter, i already have a 6.5 alpine in the front and a 10.2 alpine in the roof!
Dec 31, 2007
1,479
Reading
or get an oem sat nav centre console. That way there would be a lot less work to do if you go cutty cutty choppy choppy
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
:rolleyes:DOH!!! top tip there that man
get a nice screen flat in one of them and look oem too
