I used some heavy duty velcro on the one thats stuck to the battery box, but I did'nt have enough to do the one on the washer bottle
the blue plug into the red, and the small spade ones circled in green? (colour blind), plug into the connector you pull from the bulb already in the car.finally recieved my HIDs today, however i seem to be missing something, am i?
also where do the circled connectors connect up to?
so these dont use a direct 12v lead with a relay? instead use the power from the standard wiring?
Yepthanks for the fast reponses, your a life saver, one last question black wire = negative and blue = positive ?
i just orderd 4300k ones off ebay i hope they look cool
Can you get away with drilling a hole in the black cover or not?The H7 HID blubs are the same size and shape as normal H7 bulbs, the only thing you have to do is drill a hole in the black cover that goes over the back of the head light unit
As i dont own a drill
Not really, you could leave the back off but I wouldn't advise it. You could try and melt a hole in it to the right size, maybe get a stick the same size and try and rub it through lol
