Wiring/ECU??? HELP.
Jonny95 SXE
The Irish Contender
Nov 23, 2004
339
Hi all,
I had an issue a few days back with the ibiza,
relay 167 began to buzz, this was fine for a while once I reseated it. About 2 miles down the road tie engine started to run on 3 cylinders and then down to 2 and finally one.
I was getting ECU faults for circuit to ground on the EVAP valv, air recirc valve and N75,
after a lot of testing I I have noticed that there is always 0.25 volts accros injector #4 is this normal/ok? the engine will turn over for about 15 seconds then start running on about 2/3 cylinders, no faults and all coilpacks working. If i try to rev it it wil die instantly...
any thoughts or advice would be appreciated.
all fuses are intact and I am running a new 167 relay now. could th fuel pump cause this?
/thanks all,
Jon
lemonslap
In The Know
Mar 14, 2009
320
Kent
Hi all,
/thanks all,
Jon
Check the fuses that sit on top of the battery then all your earthing points mate, if that turns up nothing post back and I will rethink
