Hey folks,
I have only noticed this since fitting my FMIC, but when driving it's not audible at all, but when parked up, it sounds like the fan is on, but not quite as loud as the fan, if that makes sense?!
I have changed the 3 fuses on the top of the battery as they had gone and my a/c and were not working properly.
Since doing that they all worked fine.
It is pretty much like the water cooling sound you get when you turn the car off, except its' on even when driving.
At first I thought the car was just hot, but this is even after a 10 minute drive, and the front 2 fans are NOT spinning.
I've also eliminated it being the fan behind driver dash (the small thing!) as I changed that a couple of months ago and it's fine.
You can hear it, when your parked up and the engine is idling, it's barely audible, but it can't be good if it's a fan constantly running...
Any ideas?
No fault codes by the way...
Any ideas?
