remote fob
sionowz
230
cardiff
The 16ver ive bought only came with one key...the non remote key. What are my options...is it best to install a toad or similar alarm? or can i reprogramme a new fob?
Sorry if this has been done loads...i did search but couldnt really understand
cheers
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
the remote part is easy just a quick programming sequence
hard part is the key blade which needs to be the Y shaped one to accept the remote + chip programmed to the immobiliser
personally i would try a local locksmith to see if they can clone you a 'remote style' key and then program the locking part yaself
sionowz
230
cardiff
ok, will try that..but how will i get beyond the imob? will the locksmith be able to clone the transponder? There are some seat remote keys on ebay...and i get that i can get a new blade and reprogramme the fob..but as i only have one key how would i duplicate the imob transponder?
any help much appreciated!
gticupra123
146
berkshire
A mate of mine is a car locksmith, they can do everything you need, cut a new key, programme it etc.
But trust me it wont be cheap!
orangemuffin
i love you all.......
Sep 24, 2008
1,747
yesterday
OllieL showed me is VW flick key he had done, its pretty smart, i'd get one of them.
The keys with blank blade are about £30 off ebay but i think you an get the cheaper.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
not all of them have the right kit to do it with mind as some just cut the metal
this place has the kit to copy em and can order a key in but only a solid one :(
Crwys Key Cutting
96 Crwys Rd
Cardiff, CF24 4NQ
029 20344799‎
mind you could always get a remote cut and swap the chip over later >?
sionowz
230
cardiff
That was quick! cheers for that....so let me get brain into gear.. could they copy the transponder into the y shape remote key blade and then i find the fob myself? or am i confused...:cartman:
joey-gti
i have the exact same problem and im well confused now :-o lol, im guessing it be easier to take it to an alarm place and get an aftermarket alarm with rcl????
sionowz
230
cardiff
what ive done is bought a remote fob/key from a gti breaking on ebay (12 quid)and coded it in...now i need to buy a blank blade and take it to a locksmith that can clone the transformer. at least i have remote locking now tho :)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
This one is the non remote or solid type key (the immob chip is inside at the base of the metal part) usually need to destroy em to get the chip out which is handy if you get a copied key or a spare one and want to 'make' a remote locking version as below
This type is the remote (or Y type) and is what you will need if you intend having a remote locking key as standard, the immob chip sits to the side of the Y section
the immob chip itself is passive (you dont do anything to it in normal operation) but will need to be either cloned/copied or programmed to the car correctly or the car will just for up for a split second then shut off when you attempt to start it
The remote control (buttoned bit on left) is a 'dumb' unit and is easily programmed to the car wether it is new or used previously, there is a few (loads now) on what to do and how.
note both pics for reference as the blades (metal part) might appear different on your own keys (ill edit pics to suit later )
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
you know the flip key flapper, do i just take the transponder out of my y-shape key, and put in the flip key? and sorted? (once the key is cut on the flip)?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
the later one i guess you are meaning
yes swap immob chips over (i usually glue em in (1 drop) just in case)
you will also need a metal blade to suit or cut/drill an original
remote program is a toughie as you will need the right code+freq to program em and i never managed to find one - have heard it done though
ooh and big hands and heavy duty pockets as the flip key is heavier and more cumbersome when in a mk2 ignition - i went back to an original
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
really? forget it then, i just about got my car running again lol
had enough immob problems for a lifetime lol
