do i have to remove battery to fit new head bulbs
AviTurbo
Beeza FR 2005
Apr 17, 2009
132
Israel
today i got my philips diamond vision h7 head bulbs
and i don't know from where to start , how to remove the car battery ? there is any thread here / guide showing how to do this
i'm afraid to do any damage - (is this necessary to remove battery?)
thanks alot
bald_eagle
yeah its blue but i like
Mar 25, 2007
528
headlights are not too bad to change if u got small hands like me or if not get the kids involved:D
no need to remove the battery,
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
if you remove the headlights you will need to have them realigned, (makes it possibly worth shredding your hands to save some cash)
AviTurbo
Beeza FR 2005
Apr 17, 2009
132
Israel
i saw on some threads before some guys here remove the front bumper and headlights
i guess the germens never thought about replacing bulbs
how do i remove the battery
? step by step if possible
Torquemonster
301
:) My independant dealer did it(without removing the battery).He had bother with it being so tight,so he went into the workshop and came back with a long screwdriver- and used that to do something.Seemed to work as the bulb was replaced in no time.
Sorry i don't know what he moved with it,i couldn't see what he was doing.:(
the_fbi
'05 Fabia vRS
Jun 14, 2004
191
Northamptonshire
The offside is easy enough, the nearside however is a bit of a pain to get the metal clip back over the rear of the light.
What I ended up doing was putting a cable tie around the middle of the metal clip and doing the cable tie right up. Then you can use the tail of the cable tie to pull the clip back over the cover after its on.
UncleFester
Grumpier by the day!
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
spot on tip - done this with my dads Xtype Jag for the same reason.
tkjeeves
Blue
Jul 13, 2008
333
oxford
there's a plastic support on the passenger side light that is between the main cluster and side cluster that fooked my hand to peices, had to sand the edges off that!
AviTurbo
Beeza FR 2005
Apr 17, 2009
132
Israel
i manged to replace the bulbs today without removing the battery , ofcourse it costs me with 1 litter of blood on my engine bay but never mind
the plastic cover of the parking bulb and signal indecator felt into the wing
i tried to drive fast and brake but i't can seems to came out of there
there is any way to buy the triangle plastic bulb cover?
if one drop of water will touch the wires then i will be in deep s%$T
AviTurbo
Beeza FR 2005
Apr 17, 2009
132
Israel
