Clutch sticking
seddi
hi all, ive had my cupra for nearly 3 month now and about 5 times when ive been changeing gear the clutch pedal has stuck down. im just wondering if anyone else has had this problem or has any idea what it could be?
Sri Ryan
Mine does it everyday, lol, got to lift it up with my foot, I'm wondering what it is too, :)
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
master cylinder i was told. Mine did this for a while, kept sticking on the floor and had to use my foot to pop it back up to the normal position. Its either leaking or the bleed nipple is loose.
ian_cupra
could also be the spring behind the pedal, i'd check that first guys
Dec 3, 2007
2,475
cardiff
the spring is fine on yours ryan and the pedal has been welded. so i know its all there. the master cyclinder sounds the likely culprit. rhysox had this issue after this pedal snapped. maybe this has caused a few issues down the line.
new cyclinder aint much if i remember correctly
seddi
thanks all, ill have a look and see if i can sort it and let you know.
Sri Ryan
okie kokie, cheers mate :)
