Autogauge vs Autometer Phantom vs Glowshifts
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
I'm looking for the best OEM look for a 52mm gauge i'm fitting.
Just ordered my grey single 52mm Nomad pillar, and want a cush gauge to fit in there.
I've searched and come up with these three.
Autogauge Halfords £19.99
Autometer Phantom Scooby-Mania £45
Glowshift USA Ebay £40
I want it to be white with black bezel and illuminated red to match dash. Any opionions on what is best?
From the night pics I've seen some gauges suffer from 'illumination bleed' when on the red mode, to me this looks cheap. I want one where just the numbers and dial lights up red.
What to get?
Ronin225
4,652
22
Worcester
I have autometer gauges and think they look very OEM, but the standard bulbs are a bit pinky.
If you were to replace or darken them with more red they would probably be spot on
Deleted member 20376
i think there is guide on here that was donem they used a the white dial with a pinky/orangey light they just replaced it with a red one.
BBoy82
Dan the compressor man...
Oct 25, 2008
293
East Northants
Im gonna order a phantom II, and paint the numbers and markers with red transparent lacquer. Im gonna hafta cut the outer housing to remove the lens on the front, but its the only way i can see of getting the exact match.
Watch this space!
Dan
J0N
Defected!
I've tried all 3. The Auto-Meter was the most accurate but the most expensive and as mentioned above the back light was not the best, mine was like a dull orange glow. I did'nt like the Glow-Shift right from the start. I might have been unlucky because plenty of people on here like them but mine rattled, read lower than the Auto-Meter (because it did'nt return to zero), took 3 1/2 weeks to arrive and if you get it from eBay USA you get stung for another £13 for duty tax and Royal Mail fees when you pick it up from the Post Office. The Auto-Gauge (Halfords) ones are the best all round for me. They're pretty cheap, read ok and match the LCR instruments both day and night. Shame about the silver surrounds.
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
Do the surrounds pop off easily to be sprayed black?
turbin
Autometer. Quality seems good.. Not 100% similar at night, but that's ok for me. They work.
Pabs
5,936
Basingstoke
I went Autometer - check out my guide on here for pics:
http://www.seatcupra.net/index.php?option=com_content&task=view&id=540&Itemid=6
Accurate, good build quality, and matched in very well. Only slight dissappointment was the backlight - it did bleed around the gauge face, rather than just illuminate the numbers. Definately swap the bulb for a red LED bulb tho - I went for the 4-LED configuration and was a perfect match for the dash colour.
