i need a wiring diagram for the instrument clusters on a mk2 ibiza / mk3 golf, i still havent figured out the tacho signal and water temp signal and its f**king me off now. i cant find a detailed diagram of the cluster anywhere.
i need it to show me the wires coming out of the panel, and the colours and what they do.
Ta if you can help
EDIT:
not a cluster wiring diagram but for anyone wanting to wire an aftermarket ecu to the rev counter it may prove useful
Well on a SEAT Ibiza and presumably on a MK3 golf i have found the wire that needs tapping into to make the rev counter work.
Thats the back of the fusebox
you need to tap into the following wire on plug G1 ON PIN 12
Plug / Pin - G1/12 - Ignition Coil Pin 1 Motronic ECU - Signal - Tachometer - Colour - Red/Black or Green/Black
On the above cars the signal needs to be a pulsed positive (+)
The QPENG ECU i have gave me a pulsed earth signal for some reason, not sure why so youll have to convert this somehow if you have the pulsed earth
Ta if you can help
EDIT:
