ibiza130 - do the forge pipes or samco hoses make a big difference?
How long roughly would it take a garage to fit a Seat FMIC with Forge piping?
is it me, but isn't that bend quite sharp and should be a smooth curve?
also with it being twin pass, did notice a pressure drop (more than single pass?)
That is a sharp bend yes - but you only get that with the FORGE Fmic. The Seat Sport doesnt have it and is a lot better fitting, alot sturdier AND a bit bigger pipework than the FORGE cooler. Also - you can see it comes from the cooler, back on itself greater than 90 degrees, then goes down to another pipe which takes it back the other way nearly 90 degrees again!!! The Seat sport one just has one 90 pipe off the cooler, then goes straight to the bottom pipe and along the engine bay. MUCH better setup!
And twin passes are the only option for the Mk4 Ibiza....you can get a single pass made but by the time you've ran the pipework all round the engine bay - you're gonna get some lag!
I didn't notice any pressure issues admittedly....
just to check, is the seat sport FMIC the same as the standard FMIC on the Cupra PD160? Mine has some superficial damage and I'm having a shop around for a replacment
ive got i forge fmic on my petrol FR didnt take long to fit but did have to cut some out of the crash bar...
The Seat sport one as in "OEM from Seat?"
if that is the case then Forge's design is quite poor in this instance from looking at the bends
the FMIC on the MK3 ibiza cupra which I had was much better quality in terms of pipework
odd that is seems such poor quality from Forge
Well I think based on the comparison images alone I think i'll go with the Seat Sport FMIC. Just gotta search for the best deal now
