today i have realligned my timing and rebuilt that side of the enginge, how ever, once the car reachs 90degrees and you start to rev it the oil pressure light comes on, but when it is just ticking over at 90degress it is ok, i removed the sender to see if there was any oil at the top of the engine and it spewed out oil at a fair rate so there is deffinatly pressure, also the oil pump pully is as tight as it will go so theres no way the pump is slippng, yet the light still comes on, maybes there pressure return valve is sticking open? does anyone have any ideas? thanks.
