yep its when you come off acceleration, when in neutral best sound on mine is about 3500rpm and when driving its about 2500-3000rpm... makes it at other rpm's but there the best sounds on mine
hi guys
took the car in to infinity (after taking rich to JBS and collecting his hybrid cupra up) and had my cat removed.
it is sooooo loud (maybe too loud?:shocked:)
will put a vid/sound clip up tomorrow
I think there are two variables in this, the first being the turbo.
I've never heard a PD100 make this noise, but cars runnign similar setups on the same turbo often produce different results too.
The second, and which i think is more likely the case, is the exhaust. I think its down to the shape of the exhaust, and the bends.
The leons always seem to make the noise louder than the ibiza's. They have a longer straight section at the end of the exhaust. I think this is the reason why.
will be posting a video soon of a drive by.
as you can hear there is not any pigeon in my car but....... there is when i change from second to third so its strange i think its just going to be in difference spots for me :shrug:
let me know.... i first thought it was too loud
cheers
ah so this is the "pidgeon noise" i like that sound haha, aslo if you do still want a dump valve, Forge actually make one for diesels, but its quite expensive for a part that has no performance gains.
EDIT:
So is this possible to get from an ASV 110 or is only for PD engines really?
I have one of the loudest pigeon noises and mine is a 110 asv engine ;)
this is what is going on, with a cut and a weld here and there
i have a quite loud noise when i let off and my car is standard apart from a green cotton panel filter and drilled airbox, i can only hear the noise when i let off the accelerator before the turbo comes on boost, if i let off when im on boost then the noise isnt as loud
