Carriers for Porsche boxter S rear calipers?
spawns3
In another forum they say that calipers " rear Boxer S " don't work fine . I'ts possible ?:think:
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
boxster s calipers will work ok, boxster standard rears do not as they were calibrated with 19mm thickness rear discs.
s work okay and they are red, boxster are black.
996 c2 work better and they are red also.
spawns3
Mine is the red's :D the original disc is 299x24mm on boxter S
cheers
spawns3
Hi there ,
Which is the height of the s3 discs ? I have to change the pads ? I leave here a photo to explain the height that I mention.
it's the red mark.
Nuno Silva
spawns3
Hi there ,
it's the red mark.
Nuno Silva
Sorry but i don't have 15 thread to post images :drool:
rob0904
hi, im after the diemensions of these carriers im goin to be getting some machined up dont suppose anyone has got cad data on these ive got a drawin but its for a vr6 hub and off set. really need as much info as u can give/know. i will do a group buy if i can get all the info and the price is right of course :D
thanks
rob
spawns3
Hi ,
Can i use the front pads from the boxter S to fit him on rear calipers ?
Nuno Silva
bruceR
2,558
647
Monifieth, Dundee
Not sure if you can as I think the front calipers are much bigger and use bigger discs & pads, but hey someone might prove me wrong :shrug:
Normally 6pots on front & 4pots on rear
