Having a go at installing Greddy EBC tomorrow?
jamiebennett81
going to look into installing my Greddy profec b-spec II boost controller tomorrow
does anyone else on here have one installed? (I think I recall the Moffmeister has one installed)
anyone got any pics of one installed on their Leon?
just downloaded the instructions now and having a read up on them
jonathanp
736
Coventry
do they need any inputs or is it just 12v and wiring harness to the solenoid?
Hopefully fitting a HKS on Friday if it turns up. Do the greddy's work ok on part throttle?
Prebs
662
Norway, Bergen
How did it work out Jamie?
I´ve recently purchased a Greddy Profec aswell to install in my ibiza cupra(k03s)
Was wondering how you plumped your solenoid valve into as I have read there´s several ways to do this, for instance:
-www.boostvalve.com/1.8.html
-www.boostvalve.com/overboost.html
Also do you find the Profec unit easy to "set up"
Prebs
jamiebennett81
Prebs
never got it working properly
it is still on the car and I can't control the boost
I think this is related to other mechanical issues though
I will have a look at it again when the new hybrid goes on and the boost issues are sorted
jamiebennett81
you getting problems with boost spiking, part thottle control or not holding boost?
well I connected up the EBC as instructed from the instructions supplied with the book, and it would not boost past 0.8 bar
internal wastegate, so actuator to COM port and pressure source off the charge pipe....no matter what I tried the boost would not go up or down
I then put the pressure source onto the NC port, and then it started boosting 1.4 (as what was set with the MBC)
but then it would not boost anymore and again the boost was not controllable
gave up in the end
