ECU Remapped
DDC_
I have searched this but can't find any information. I read though that when your car has been remapped it goes into limp mode constantly. What can you do to stop this?
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
Not true at all, i've had my car a year on revo stage 1 & 2 and so far touch wood, ive never experianced limp mode! It may not be the map causing limp mode at all. My bet is on either a coilpack or a MAF dieing a slow death!
DDC_
The coilpack and MAF have been replaced in last week.
I have got an N75 but what is it?
DDC_
The car was running at standard boost, got the boost turned up to about 16psi. Ever since then I had problems. Replaced the coilpack, spark plugs, maf sensor and secured all boost pipes. The car has been remapped to run the N75J valve. Can I go back to the standard N75 valve or will this not make any difference?
tarzan
cupra owner from norway
Mar 15, 2008
1,122
drammen norway
try with the standard many pepole has had problems with the n75j and many dont have problems with it.
DDC_
APR software
What problems do people have with the N75J valve? How much does it cost for the N75 standard valve?
