yeah main dealers, i got the list here; DRAIN AND REPLACE ENGINE OIL, REPLACE OIL FILTER, CHECK GEAR OILS, EXHAUST CHECK, CHECK COOLANT, CHECK DRIVE BELT, CHECK BATTERY, CHECK/CLEAN AIR FILTER,REMOVE WHEELS AND DRUMS, CHECK BRAKES, CHECK LIGHTS, CHECK WIPERS, CHECK WASHER FLUID, CHECK HANDBRAKE, CHECK BRAKE FLUID, CHEACK CLUTCH FLUID, LUBRICATE DOORS, LUBRICATE KEY LOCKS, CHECK TYRES, CHECK DIF OIL, REPLACE SPARK PLUGS, CHECK BRAKE PIPES, CHECK CLUTCH, CHECK BALL JOINTS, CHECK DRIVE SHAFT/PROP SHAFT,CHECK SUSPENSION, CHECK SHOCKS, CHECK HEATER/COOLING SYSTEM, CHECK STEERING, CHECK SEAT BELTS, ROAD TEST. thats alright then thought it wasnt too bad just wanted to make sure lol. ta mate
