oil change?
dan2008new
hi everyone,
im after the easyest way to do the oil change never done one before, was wondering the way to do it?
i have tryed the search and couldnt find anything helpfull really or any picks
cheers dan,
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
Ive got to do mine aswell its past its due date...
its pretty much a matter of undoo plug drain out oil....lol...
not sure if you have to use a new plug of not though..???
and dont forget to refill..lol..
dan2008new
i feel like a retard but i dont know which it is there is a VW badge under neath that looks removable......
but not sure
lol
No need for a new plug. You do need a new washer though.
Remember you will need more than just a 4 litre bottle to fill it up.
list:
1. Buy new oil, oil filter and sump plug.
2. Warm the car up to temperature.
3. Take off oil filler cap
4. Jack up car and place catch tank underneath the sump plug.
5. Take out the sump plug and wait until that is all drained out.
6. Then take off your filter. If your lucky you will have one with a nut on the end of it. If not then you will need a filter wrench. (careful there will be hot oil in there too)
7. Replace filter with new one with oil round the seal.
8. Replace sump plug with new washer.
9. Jack the car down then fill with oil until you can see it on the dipstick.
10. Start the car and check for leaks.
11. Turn off, let the oil settle and top up as the filter will have taken some of the oil.
lemonslap
In The Know
Mar 14, 2009
320
Kent
My dealer only does a replacement bolt complete with washer (every other car I have worked on you can get them separately from the dealers), don't mind though its only £1.07
