Inlet manifold cleaning... (internally)
Nov 10, 2004
1,000
Colchester, Essex
Hey folks,
Heard it's a good idea to take off the inlet manfold clean it inside, any recommended products for the cleaning part? I remember I did a similar thing on a Fiat with carb cleaner ( I think it was called power spray or something... It didnt seem to do much other than cause a ridiculous amount of smoke from the exhaust lol)
And is a liquid gasket sufficient when putting it back on, or a replacement one better?
Many thanks,
Sean :)
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
yes you do it the same way as you did with the fiat, and it should cough smoke from the exhaust when you done it.
take off the intercooler pipe from throttle
spray carb cleaner in it
either brush with a tooth brush or leave it if you don;t want to brush
collect excessive carb cleaner which might drip
put pipe back on
now here is where the catch is:
throttle can only be properly realigned with vagcom
others say that you can disconnect battery, leave it for 5 minutes, put it back, turn ignition (don;t run engine) and wait till the squeeking sound ends. THis is not the case though. Only possible with vagcom.
anyway, if you don't touch the butterfly thing in the throttle and simply spray the carb cleaner will get everywhere on its own.
Lastly, run car with slightly revving it.
job done
last note: there is many threads on this. search would have been good place to start ;)
Nov 10, 2004
1,000
Colchester, Essex
Hallo and Goedemorgen to you Reuvers :)
I did a search but it came up with injectors and 4 bar FPR chat lol.
Thank you for explaining it, I have a friend with VAG COM so that shouldn't be a problem to align it with that.
I will most likely use a brush as well, so best to push the butterfly thing in and spray down it like that?
Do I spray it in with the engine on? (I did with the Fiat)
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
surprising to see some Dutch on here lol. Its goedemiddag now though ;)
yes its no problem keeping the inlet attached to the block. If you have full vagcom then yes, you can open the butterfly however you want, and scrub it with a brush (that would be the most thorough way)
as for realigning:
From Ross Tech for DBW 1.8T
Turn the key on but do not start the car.
[Select]
[01 - Engine]
[Measuring Blocks - 08]
Group 060
[Go!]
[Switch to basic settings]
Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
[Switch to Meas. Blocks] button and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
I suspect you risk more than you will ever fix from this personally.
just how dirty do you think the inside is, and what effect do you think it actually makes to engine running?
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
maybe its good to say that I have never done this myself...
however I have read quite a few posts on here where people claim good results from this. ie better idling and some who claim power comes smoother throughout revs.
even read somewhere that some English 'Tuning' (hate that word) company you lads refer to quite often, said to do it every 10 K
but don't know this first hand
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
More than cleaning the tb or inlet mani i would say more of a clean of the injectors and spark plugs would have more of an effect on the efficency of the engine running...
lemonslap
In The Know
Mar 14, 2009
320
Kent
I must admit I was shocked at how dirty the inlet system was on mine (1.4 common problem though) but the inlet manifold looks imposable to clean inside, I cleaned the throttle body and the results was impressive with cold start and general running much improved Btw I use brake cleaner as it seems better at removing carbon deposits/
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
the op is saying cleaning the inside of the inlet mani..
clean throttle body, yep, there's a benefit if its gooped up.. but the inlet manifold?
Nov 10, 2004
1,000
Colchester, Essex
It's my fault:redface: I meant throttle body!
Should I replace the gasket at the same time? At the moment it looks like theres liquid gasket on mine, so it's been done before at some point by a previous owner.
I think it was 10k boost I used ages ago on the Fiat... Although im sure that was all hype and marketing! (But suckered me in! lol)
Nov 10, 2004
1,000
Colchester, Essex
I was thinking... Do I need to even remove that part - maybe could just take the I/C pipe off and spray the cleaner through the TB that way? (have someone keeping pedal at part throttle to let it open)?
Pulsebassuk
BASS MAKER
Jul 15, 2004
334
Colchester Essex
Hey folks,
Many thanks,
Sean :)
It was called 10k Boost .. i remember as I sprayed it whilst you reved it up
