the boot lock wont open when u unlock the car with the key or with the fob it makes the noise as if its opening but isnt . could anyone shed any light on the subject. thanks gb
I had this issue about a month or 2 ago. Does it sound like it is engaging when you press the fob?.
What happens is that you may not have unlocked it as normal once with the 2 blips of the unlock button. Say delayed slightly between presses. You've not noticed and lifted up the handle but of course the boot was not opened correctly.
What happend on mine is that when I lifted the handle the first time as above the rotating bar connected to the handle inside moved upwards as normal but stayed upwards. If you use the key all you do is move a black sliding bar left or right. This is no good if the handle has lifted the other bar out of the way. It will never meet the key bar.
No amount of pressing the button will unlock it as all this does is move a sliding bar left and right. It then engages with the moving up part of the handle which you then use to open the boot.
It is difficult to explain but remove your parcel shelf and push the back seats flat. Climb in your boot and undo the two screws that are in the boot grab handle trim. 1 screw in each side. Remove the bulb covers also.
Then gently and very carefully grab the plastic trim at the top near the wiper motor, with hands as wide apart as possible so not to put too much pressure on part of the trim. Start to pull quite firm the trim away from the door. It is stiff and does hurt your fingers. I found it easy to start gently rocking your body to and fro with each pull and gradually increase the pressure. It will creak and you'll hear clips pinging off inside. Don't worry as long as you don't see the trim start to crack or go outta shape then keep pulling.
Once off place all the bits back in the house so not to lose any
. Then sit in boot and close all the doors. Now if you pull up the thin metal bar which looks like a bit of coat hanger, the boot should open. Shut to boot carefully as to not bang your head on the rear screen
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
I managed this twice
Have a play with your fob, opening and closing the boot. You'll start to see after a few goes how it all works etc. Now you can grease the white piston that goes into the tube and you can grease the black slider. However my issue I think was that because the boot is hardly used and has not been from new. The handle when lifted that control the moving black top bar up, was a bit stiff. This is difficult to grease and I think just needs a bit of wear and tear, so just lube it up with WD40 and some vaseline and keep manually moving it for a good number of goes.
It is also good to have someone lift the handle on the outside for you so you can see what should happen after the fob has been pressed.
I left the trim off (it's still off because I'm lazy) and I looked at the mechanism from the rear screen while lifting the handle. You can if it stays up put the key in the lock and open the boot manually while lifting the handle further up. A couple of wiggles and some presses on the fob and I managed to get the handle slider back down.
The main point after repair to use you boot a bit more often. Also do not lift the handle unless you are sure you used the fob correctly and you hear the boot mech move. If in doubt then lock the car and unlock again. Also make sure you cover the white piston part, black slider and the black rotating bar in WD40 and grease/vaseline before putting on the trim.
It might sound daunting but it's easier to see once your in boot with a few fob presses. If you get stuck then give me a shout as my trim is still off and I can still see the mech. I think I will even take some photos of the mech so other people can benefit from seeing whats behind the trim.
I will follow up soon
