Exhaust hanging quite low
vwbassett
Joined the Dark Side
Aug 13, 2007
963
53
Surrey
Hi, looking at other owners pics on here my exhaust(LCR) seems to hang pretty low. I can easily get my hand in to wash the hole top of the tip - is anyone elses like this or is it close to the bumper cut out? Im guessing the bushes might be past there best but just interested if its normal or not before i visit a TPS dealer to try some replacements?
Adam
Mully
Fezza 1.4 At the moment!
Apr 22, 2008
89
North East England
High my cupra R exhaust hangs a bit low as well but when i look the backbox is at its highest so therefore i think thats the way there meant to be but im not 100%.
vwbassett
Aug 13, 2007
963
53
Surrey
Thanks for the replies, i can get 3 chuibby figers in so think its dropped a bit but it has done 60k so i guess its worth trying a new exhaust rubber
karlosR
TORQUEY, NOISEY V6
Mar 10, 2006
1,469
BEDFORD
Put a couple of big cable tie's around the rubber, a new one will only drop again.
either that or a jubilee clip. but, neither of those are permanent solutions. an exhaust U clamp around the rubber mounting will stop the backbox hanging too low and also stop the backbox hitting any rear ARB that might be fitted.
GRD
167
Sheffield
Visit site
Are you sure the hanger bracket that is situated just before the back box has not corroded off. :(
This is the most common cause of the exhaust hanging low - I just welded mine back on! ;)
Thet only seem to last three years :cry:
dans-fast-cupra
maybe the clearance is enough to not effect the paintwork on the bumper - if it aint broke dont fix it!
vwbassett
Aug 13, 2007
963
53
Surrey
Theres no paint around its just the plastic add in on the cupra R, it looks odd so im getting under it soon just holding it off as those damn jacking point covers are a pain in the arse to get back in sometimes.
J0N
Defected!
This is a common fault, mine was exactly the same when I first bought it. Had it welded back on for beer money, took longer to put the car onto the lift than it took to do the job.
Deleted member 20376
ive noticed this on mine too, it hangs low i can easliy wash the tail pipe mines only a few year old only got 32000 on the clock.
think ill jack it up and have a look.
