brad1
Where did you get your downpipe from mate? It's a powerflow isn't it?
Milltek downpipe with a silencer, supplied by AmD
As brad said.Thats good to hear! Sounds like your happy with the car again
Correct!Milltek downpipe with a silencer, supplied by AmD
As brad said.
Yea I am quite happy with her and I haven't even done a spirited drive yet. I am glad that this saga with the car is over. I can now concentrate on keeping her clean and some cosmetic upgrades.
Correct!
ha!Wouldnt be no one else apart from AmD would it now mate lol
What's the "wingnut mod" Maz ???
Something you petrol boys can't have
Still none the wiser Maz ??EGR stealth race pipe.
I dont have a boost guage YET however its boosting 1.9Bar.
Oh right. Well it was on the fly decision and a minor cost to see if it really does work. Your right probably just the balancing making all the difference.Nitrogen in tyres only makes sense if you get the tyres put onto the rim in a 100% nitrogen environment in the first place. Seeing as you can't remove all the air from the tyre in the first place, you're always going to have moisture and "normal" air in there too, which negates the point.
We run nitrogen in our kart tyres, but they get significantly hotter than road tyres and run much lower PSI where a variation in pressure causes more of an issue.
Any difference you are feeling is down to either the balancing or you wanting to believe there's a difference.
Look on the bright side, if they keep getting the odd £4.00 for ideas like that, at least they will still be in business next time you need something.
