Mine wasn't a simple fit, but I took it to a good garage (VAG specialist - Storm Developments) to fit while my car was there for a remap. Before the strut towers could be marked for drilling, the brace had to have a metal loop on the off-side removed as this would have damaged the water-line over time and on the near-side the bracket had to be shaped to allow the bonnet lifter to operate. The drilling I felt I'd prefer not to do myself, but I know a few people have done themselves. The nuts/bolts/washers should be high strength steel (such as wurth) due to the forces involved.have seen those, would like to see a pic.
Was it an easy fit? I know some need cutting by the bonnet lifter
mine wasn't a simple fit, but i took it to a good garage (vag specialist - storm developments) to fit while my car was there for a remap. Before the strut towers could be marked for drilling, the brace had to have a metal loop on the off-side removed as this would have damaged the water-line over time and on the near-side the bracket had to be shaped to allow the bonnet lifter to operate. The drilling i felt i'd prefer not to do myself, but i know a few people have done themselves. The nuts/bolts/washers should be high strength steel (such as wurth) due to the forces involved.
only a pm
As long as the engine doesn't get in the way, the turrets will be in the same place.Does the S3 one fit the Golf MK4 GTIs?
Matin.
