I assume that these are the stock SFS pipes? albeit reinforced and not metal ones with silly joiners.
Pat, I think your normally informative on many things and a good help in many things, but i read your replies to be almost targetted and aggressive towards Maz problems with SFS?
Hi Roger,
As i said later to Maz on msn ... it wasn't mean to come over as personal which admittedly it does look that way.
However SFS & Maz issues aside, all of this is still very much 'development' work and should be treated as such - i expect teething problems at every step and i've had my share of them too. All i can promise ( as i've said to Maz) is that as i sort out these issues and get things like pipe lengths etc sorted i'll let people know.
Thats correct.I assume that these are the stock SFS pipes? albeit reinforced and not metal ones with silly joiners.
Well its a solution - if they make it strong enough and it does the job then yes I am happy.Wrong ones sent out???? Sounds like the old TD2 routine to me.
Well if it gets you sorted and keeps you happy, then that's got to be a result.
Yep got to wait and see what happens. Lee said he would call me today so will await the call.
I will await judgement
No worries Pat, its the problem with reading forums can be seen in many lights...
Its certainly developement, that all of us have in different branches
costly to some and not to others
By the time you get around to any of this, all of this should be sorted so as you say, unlucky for some and lucky for others.
Great idea, except be better to use the post number, not the page number. As the number of posts/page is configurable in the user CP settings, so won't necessarily be the same for all users.Thread was getting quite big so thought I'd make an index. Can be found on page one with the Mod list too.
Cheers.hi mate nice car, was wondering were u got the fr dead pedal and how much it cost!
SFS are still making uprated ones. Just have to wait for them to be made. I'm in no rush now they can take as long as they need.So whats happening about the pipes ???
Cheers mate. The car hasn't been RR with OE pipes and new map. I suspect the car is around 230 and 360-370lb/ft. I wont know till the weekend or in a couple of weeks time.very nice car mate, what power is the car running now it has settled down?? and are you gonna be pushing for much more?? injectors, methanol etc??
PD engine is quite strong. With race injectors and methonal your looking at 260 easily. Prepare for the car to smoke a bit with race injectors and possibly cam will wear also. TD2 turbo is good for 240-260.whats the most power you can push on the 1.9 (standard internals) with a TD2, looking at race injectors, methonal nitrous etc
