yesterday was one of those bad days! nothing went to plan...i had started to do the axle flip but thought id make my own saddles and locating pin, welded all up, sprayed the axle up nicely..everything looks ok....changed wheel cylinders also so no
problem bleeding the brakes when back together
finally get the axle down to the caddy..open up my pakets of gear i need to find ive only been sent 2 u bolts!
so can only get one side bolted up..then went to stick the shocks on as everything is being supported my axle stands anyway..only to find the bolts are not long enough! now need to get some more 2moro from somewhere as well as 2 u bolts!
due to not being able to get the back end together and on the floor again i couldnt start finishing the front wishbone and coliovers which i started last week which had also came to a holt due to not being supplied the rear bushes!...the only thing that has turned up on time and is all good my the looks of things is al's top mounts! wish i had ordered my u bolts from you now tooo...
so all in all i didnt have a great day and in a mood
