A few VAG-COM errors...
paradigm
I hate the orange game!
Hi guys,
I know I could search for each individual code and try and work out what they mean, but I'm in a huge hurry (car is meant to be getting traded in soon), and need to sort the following out ASAP:
5 Faults Found:
17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
P1200 - 35-00 - -
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-00 - -
16622 - Manifold Pressure / Boost Sensor (G31): Signal too High
P0238 - 35-00 - -
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 - -
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
P0106 - 35-00 - -
Now, what is the N249, I hear it mentioned a lot, but don't actually know where it is in the engine bay, how much is it to replace (just the part), and does anyone know the VAG part number for it?
Fuel Trim: Bank 1? is this referring to the pressure in the rail, or the pressure for injector 1? If its the rail, would this indicate that the rail has a pressure leak, or that the fuel pump needs replacing?
Sensor G31, where is this, would this be caused by the next fault (pressure drop?), or would it more likely be a failed sensor?
Pressure drop between turbo and throttle, check DV. Well I've "checked" the DV, it isn't loose, I also get the same error if I use a forge 007p or the stock DV, so could something else be causing this (the N249 issue perhaps?)
The final error I assume is a sensor failure, which sensor would this be?
Any help is much appreciated guys, I'll owe you all big time after this!
Mar 26, 2007
2,020
S.Wales
Does the car drive normally? If so why not trade it in as is and let the garage deal with it? That might seem harsh but it really is a case of buyer beware.
paradigm
No it doesn't, it is very hesitant on the throttle (ok when rolling and if you don't use WOT). It is driveable, and nothing sounds amiss until you try and plant the throttle pedal.
I'd rather get the problems fixed if possible, I'm honest like that :p
edmong
GHE Tuning
Aug 15, 2007
567
Plymouth, Devon
I would have to say you have a boost leak and the codes point out the dv and surrounding hoses. Check all hoses for splits. How old is your 007p?
paradigm
Well, I found a spilt hose between the N249 and the intake manifold, so now the car idles correctly, but is still hesitant under wide open throttle. It's definately down on power and not boosting properly.
I've checked all the major turbo pipework, no splits or cracks, so now I'm at a loss?
Any ideas?
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
G31 is in the aluminium pipe that connects the two intercoolers.
F96, the altitude or barometric pressure sensor, is integrated into the ECU.
paradigm
Are you sure, is it not in the top hose between the passenger side intercooler and the throttle body?
As I have found that this sensor is cracked (across the connector, and as such the connector wobbles around), so have a feeling that it might be this!
Part number: 038 906 051 D ?
If I unplug it, I don't get any more errors on the VAG-COM, but the G31 error changes to "open circuit", so can only assume that this is the G31 sensor.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Sorry, misread the diagrams, it is as you say in the top pipe, from the intercooler to the throttle body/inlet manifold. There is only one other sensor in the pressure side of the inlet, the temperature sensor G42, and that's in the manifold itself.
Lodgey180
WoOoOoOsShH
May 3, 2008
1,046
Middlesbrough
www.mootr.co.uk
part number 038 906 051 d comes back as your g31 fault
boost preasure sensor.. could have something to do with the n249 and dv faults
paradigm
I've got all the other errors cleared (and staying cleared now), after finding a vac leak in the manifold (small pipe that goes between intake plenum and N249 had a split), and replacing the N249 with a spare one I had lying around.
As I say, the only error I have now is the G31 error, and given that the connector on the sensor appears loose (and the casing looks cracked), I'd say its a pretty sure thing for it to be a physical issue with the sensor.
At least, I hope so, given I've just ordered one (at £72!!!!).
Back on the Forge DV at the moment too.
paradigm
Would this be causing my throttle hesitation on wide open throttle though?
It happens from idle, but not above 3,000RPM (although there is no hesitation above 3,000RPM the car is still evidently down on power).
What else could it be? I've changed the coil packs, changed the injectors, and changed the FPR.
Mar 26, 2007
2,020
S.Wales
I'd have thought it could do. Is the error intermittent? Perhaps the crack is causing it to over read and cut boost without need to.
paradigm
The problem is consistent, cold, hot, first run or last run of the day. Always stuttery on WOT so long as the engine is less than 3,000RPM.
The crack is actually across the plug, so it wouldn't be causing an air leak, just means that the potential for the plug connections to be broken is high, infact I'd go as far as to say that the plug connections will most likely not be actually connected to the sensor internally.
Jul 4, 2010
2,170
Cambs
This is exactly what is happening to my car at the moment G31 falt that wont clear missfiring under 3k fine over 3k.. i know its an old thread but its so frustrating when people dont post up the solution.. i can only assume that the new g31 fixed the problem as it all went quiet after he ordered that.
