Power holding back
The MoffMeister
Half Hoff, Half Moff.
Apr 4, 2006
2,937
colchester
hey all just a quick one.
Has anyone ever had the following symptons with there car?
you put your foot down on accelerator pedal hard and around 3k and sometimes 4k it seems to hold back then all of a sudden it kicks in with the usual wollop, it happens in any gear and its annoying have got vag com just waiting oon software but no eml light on
any ideas
cheers all
The MoffMeister
Apr 4, 2006
2,937
colchester
not sure might be got the whole lot replaced a year and a half ago or so done track days etc thought it might be something in engine bay like maf etc
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
if your coming to the meet tomoro i'll bring my vagcom cable and software and we can have a look rob?
The MoffMeister
Apr 4, 2006
2,937
colchester
cheers danny but not coming to that mate
tris i've had them go and it sounds horrible to when they go so dont think its that, maybe maf, or something similar who knows
cupra-rich
423
coventry
i had the same symptoms, thought is was the MAF. no fault code on vagcom. turned out to be the dredded clutch slip. new clutch kit in no problems since.
gulzar
LCR jabba'd
Oct 1, 2007
178
think it sounds like n75 valve which controls boost, or the d.v, or the maf. need to do some logs and try. i'd recommend a vag com on it, check mass flow rates . failing that have a look at the d.v, check for leaks in that area, and finally n75 valve as this mediates the boost the turbo gives. hope it helps. good luck.
The MoffMeister
Apr 4, 2006
2,937
colchester
i think it maybe clutch then o joy thanx viktor
its not n75 gulzar as i dont have one working on the car, need to service dv and change spring, as soon as i can get vag com i will do
cheers
Dani_b19
301
Unplug the MAF then take it for adrive, if it stops then you know its the maf at fault
holty
Inside a nice VAG
Sep 25, 2008
202
In the Hills
I've had excactly the same on my tdi.
Thought it was MAF, exchanged.Seemed ok.Started doing it again.Usually at about 3-3.5rpm, the needle drops or seems to stop climbing, then kicks back in again!
think its the big bad C:censored:TCH :cry: :cry: :cry:
The MoffMeister
Apr 4, 2006
2,937
colchester
it wont be to bad for me if it is as the cutch i can get cheaper through a friend and its stage3 and bloke here fit it last time for 80 quid so not to bad lol
cheers all
Jan 6, 2009
1,102
sunny falmouth
hey moffmeister i was just woundering if you still had those halo lights n if they would fit an ibiza mk3 i tried postin bk on the other thread but it would not let me
Jan 6, 2009
1,102
sunny falmouth
lee_woollett
285
northampton
mine does this sometimes. Foot hard down and it seems like nothing then bang, loads of boost. Sometime if i have my foot down then release the throttle then foot hard down again, its like you've hit a wall for a second then loads of boost again. Could this be the tip collapsing. I've got an oem TIP. Its not the MAF as i changed that 2 months ago. sometimes also a bit hesitant in third or forth with foot down, boosting then drop in boost then more boost then bit less boost, its only slight but i'm wondering if i have a slight boost leak. Nothing showing in VAG COM though
