3 door rear panel removal
Jan 13, 2008
32
Midlands
I cant find any explanation as to how you get the rear panel off of a 3 door . could someone please point me in the right direction.
I have just about finnished building a new MDF rear parcel shelf with a pair of pioneer 6*9 's (TS-A6921) in an i need to get at the rear speaker wiring to extend it back to my new speakers.
I have already fitted new pioneer head unit DEH-P7000UB and ordered a 8Gb usb stick . I need to get a steering wheel wiring adapter if anyone has any info that would be welcome too . Oh the head unit is fab BTW :D
Jan 13, 2008
32
Midlands
I will show you mine if you show me yours lol
i have not taken any yet but will do tomorrow in the light, before i cover the MDF with cloth, which i am off to maplin to get . then i just need to work out how i get the pics on here lol .
Jan 13, 2008
32
Midlands
ok gonna try post a few images.
y1pym4RubEf9Ozzk1rsM_GvijzkuudttWevWChbv0TtHB2Pm-v2ZpYIPDcdGdajF43UuxhpEqvuIfquM3CYBOBw0Ok_HLRI300J
Jan 13, 2008
32
Midlands
worked lol.
ok so here is what i have done and used . The MDF is standard 18mm sheet from wickses cost me 9 quid. The two extra bits in the corners on top are holding the hinges ( used the original ones ) but the offset in hight fits the 18 mm perfectly.
y1pym4RubEf9OxZlER69KA6Xvh48YWk4qU3pBQ8hPFPII9GV0du0UpGyJiQ6u0UalZH4RLCk_Nz8fDaJtDq3QxuL7VnNegdWL06
can see them in top corner.
y1pym4RubEf9OxLJX2LdpJRLPzQ8wSY_j1mxD9fjjTZPg0dUefiBJaNxnRus5RUXhlVRbgGSrS6vyVdsK7DU2psXZ7lTelIlYCI
y1pym4RubEf9Oyaz2TthloqjnIspTNAVuDofeVd6hOSwnjKcWFdpg2FcY7n3EzG0Zzxhe7vzkij6szO1wSOmqiwMOLLaX27OomD
y1pym4RubEf9OypXc_mJDaLCIDoBAgKvKYRVO-NJMHmorNvlC1OT-50yuVBete7m8L9TU4IijxvovC258IsSeYP5LG1SR7zxwW9
The back edge is a good 50mm higher than the back seat so i put a strip on the back edge to fill the gap.
I set out to make a stealth type shelf so i have mounted my speakers below the shelf and will cover with cloth afterwards so you wont se them from outside the car.
y1pym4RubEf9OzLtJzST4WtwUCwqZMmj2VsSwZQOn72Mxc6P-ZGj4gHNzAHlvVhcUC_KmsqqqnaqEqQsYFCaPI4Yf_P-kFjTfNb
I have fitted the pioneer head unit already but my 8 gig usb stick came this morning :funk: took over 120 albums.
y1pym4RubEf9OwIU6p9apD0kFhL4f3diZsd98u1WCtgv_0xexMYGebH6n4y5q4_mgysiju57dMCUElDxNWPAUvtVdSvSWB1fR6y
I love the retro analouge needle display most...
y1pym4RubEf9OxACTNQhH9nXfAGYaUTuCjCrhx7d-S9yqY3N9XT9ohqVdaovzb6B8CWEBGWsI9s5VnfeDJbQZHbCH1PHg0d0SIz
As for the rear panels well there not to bad really. you need to take the little rear top panel that holds the seat belt off well not off but undo them so you can get the panel past them. there held on with 3 screws see next post.
Jan 13, 2008
32
Midlands
y1pym4RubEf9OzKy-9Tk_0dj9X_nfOH1VA6puynOjmumkG0HhS2zS4tpMicVxz6CVpGidnBwcKhcqn4l77fQ7XUlqkCpFtUMVvs
y1pym4RubEf9Ox_E1BneXCVwXF2iftLUWjw96fG6doR5XZPXwukurd1qVW5gWaBJ1KeQfs-o6HkBhXVFkqa9hYx2IeyzVqf3VDo
y1pym4RubEf9Oz5TCBKnSDe4ywPuA-igxil77hCmAHCpA4jScbDC_AbGxhpekYJLyml4B4j3H2NOv6wnwln5qxD-ZESYtAJBTmx
as for the panel well it has two plastic type nuts which are only finger tight.
y1pym4RubEf9OwsKG8M2nlmbmWpX1fumziA0sKLhk91SWt7VQ_qkzlhHHNp9BwPgbkvRZKyDuQyutinQX11D6z1rxvNUXnaj8gF
you just pull after that and suprising how hard you have to as well but there are just plastic lugs behind it hoiding it on .
y1pym4RubEf9Owc93i0OPJcdVrwPOukdRvJsNPEgirkj3rZqHILUE3sAdiYoE5Lk55G8_kmkPgVk4JqWVH0Lm9RBcRLDBq1hMPE
y1pym4RubEf9OyEnM5VHtueKkqpDqQ2-dwjoV5LfaYV8PJTx8bLsiVP_DjTKVgt0gR8pOLLAexPXqvtGKqEnREcik8Cgj30aX73
y1pym4RubEf9OzvEamHp9uKSekGBZSJdjiciDiOxMpr78_8vrRVzBWKbBFhWsLeKadwtyAz0bwataBSf1HhhxLZ2deE7_XVs-UV
Only had to get at the wiring so was a little easier for me lol. Hope that helps someone else out at some point. :clap:
Amit K
have you got after market rear speakers, i just got some audiobhans and they dont fit i think i need adapters and im in a bit of a dilema because i cnt find any rear speaker adapters:cry:
g8rvn
154
Tamworth, Staffs
A number of people of here have made their own adaptors out of MDF for the rear 1/4, I remember reading somewhere that it is possible to even fit a slim 8 inch subwoofer in there, along with the normal component/6x9 speakers etc.
If you search it will be there somewhere
jtonline
www.jtonline.info
Matt, stealth shelf looking good. Look forward to seeing pics of the finished article.
Gonna bookmark this thread as the photos showing location of the fastners will come in handy if I ever need to pull the panel off my car. Might upgrade my speakers one day, but don't have the skill to make an MDF adapter.
i want your boot light....
See this thread http://www.seatcupra.net/forums/showthread.php?p=1918188#post1918188 and the threads I linked to there. Easy mod once you know how and have the SEAT parts.
