'Sticktion' on cluch pedal.
May 31, 2008
1,247
Mines the same, i am thinking about making some tiny holes along the cable, shooting grease in then patching the holes.
I tried lubing mine up this weekend, put it back in and 15 mins into driving it started again. I might phone up the guy who did my clutch and ask him whats going on. Is very annoying.
Heavy
79
Peoples Republic of Teesside.
My mechanic gave the car a good look over yesterday and said he didn't think the clutch felt bad. He said that as I have been driving newer Volvos for years, I have got used to a very smooth hydraulic clutch. Anyway, I seem to be getting used to it.
Cupra Kid
Has a TDI!!
Oct 13, 2005
3,380
Chesterfield, Derbyshire
Quicker changes make it smoother, i find that after a decent blast mine is very different. Theres a spring on the back of the clutch pedal if this is worn it would give a staged effect to the clutch
May 31, 2008
1,247
Ok so i just went for a drive, after staying in 5th for about 10 mins i found that the clutch went back to normal with no sticktion effect then when i used the clutch again it came back. I have checked everything, the spring, the cable and the pedal. I dunno what it is :<
Heavy
79
People above have reported that clutch and cable change has not solved the problem.
My car had a new clutch about 15k ago with a careful driver, so I think it should be alright.
I'm going to investigate the pedal joint and spring, see if lube or replacement helps.
